Masterchief87
Android Expert
Deleted
Thank you very much sirIts always a good idea to keep a full backup of the system and boot partitions just in case you mess something up later. Its an even better idea to backup everything (system, boot, and data) because losing your data and having to reinstall all your apps and do your setup gets aggravating.
Also, as long as the md5 sums for both files match the ones in the 2nd post the zips will work perfectly.
I just looked and noticed that the switcher zip has about 50% more downloads than the restore zip. It seems like a lot of people don't get the idea that both of them are equally necessary. The only use that TWRP serves being on the boot partition is that it gives you a way to flash the restore zip. You cant flash any zip that writes to the system or make or restore backups without first flashing the restore zip to put things back in their correct places.
I keep my phone RW all the time. Whenever I need to use twrp I flash the restore zip then after I'm done I flash the switcher zip again for system RW. I know I've already said this many times but never factory reset your phone from the settings menu or without putting twrp back on the recovery partition and rebooting recovery.Question good sir... I have both zips, however I have only used the one. I have kept my system with r/w access. Is this ok? I get what you said about twrp but will it cause ANY sort of issues with keeping myself in recovery? Or should I just run your zip get r/w access for when I need it, and flash back to normal?
If you have an SD card it would be best to keep them there in case you end up needing to format data.Should the zips be on am SD card rather than internal or does it not matter
I creates a nanodroid back up of my system and installed butternoob and it works fine but I think I deleted my nanodriud metro PCs zte zmax everything is working fine just wondering how to install switcher on my systemHi everyone, something that has been bothering me is the fact that in order to have write access to the system partition while booted in Android, you have to copy the boot.img to the recovery partition. This has been causing a lot of people to brick their phones because they messed something up and didn't have a recovery installed. My idea was to create a pair of flashable zips that will allow you to easily copy the boot.img to the recovery partition while still having TWRP installed. This allows you to have full root capabilities while still having TWRP installed on your phone. I went ahead and made these zips for my MetroPCS ZMAX and they work so I have decided to share them, hoping it will decrease the number of people bricking their phones.
If you are reading this, I will assume that you have already at least obtained temporary root with kinguser. I will not go into detail on how to do this because there are already guides telling you how to get temp & permanent root and install TWRP. If you havent yet done so, install ZTE ZMAX TWRP built by the master craftsman hroark13 before you read any further. All credit goes tohroark13 for building TWRP for all of us. All that I have done is put together some flashable zips to make things easier.
DO NOT REDISTRIBUTE THESE ZIPS OR POST DIRECT DOWNLOAD LINKS!!!
This is very important because if you upload these zips and one of the files gets corrupted it may potentially brick someone's phone. It is also very important that you dont post direct download links because anyone who downloads these files needs to be able to check the md5 sums to make sure that they didn't get a bad download.
Download links and instructions will be in the 2nd post shortly.
Please make sure that you thank hroark13 for his work. Hit the like/thanks button to show your support or buy him a beer.
What condition is your phone in now? Can you boot into android normally? What about twrp?I have a question I installed it and was able to to install viper4android and wanted to change the drivers to power saving mode so I went back into twrp and I flashed the wrong file .I flashed theMPCS_TWRP_&_BOOT_RESTORE.zip. and it told me no is installed I was able to get butternoob back on and my system went back on but now I was trying to flash both the files in twrp and it keeps on saying failed what do I do
If you power the phone off then turn it back on by holding power and volume up, does it go into twrp, or android? Also, you need to make sure that zip file signature verification is turned off in twrp. I don't sign my zips so if signature verification is turned on, twrp will refuse to flash them.Yes I was able to hold the volume key and it went into butternoob and it went into the phone setup and installed everything and yes I can boot into android normally but tried both files and it keeps on saying failed
I actually didn't soft brick my phone. I checked the md5 after copying the files to a flash drive and saw that they had been corrupted so I deleted the copies and copied them again and checked the md5 again and everything was good the 2nd time. I like the video but I think I'm going to do my own and add it to the op. Thank you though.@DeadDude, I made just such a video yesterday.
And Masterchief87, I sent you a PM, but it looks like you are already talking to him
It goes into twrpIf you power the phone off then turn it back on by holding power and volume up, does it go into twrp, or android? Also, you need to make sure that zip file signature verification is turned off in twrp. I don't sign my zips so if signature verification is turned on, twrp will refuse to flash them.
What about the zip file signature verification, did you make sure that it is turned off?I have to do it a few times before it goes into twrp
Yea its turned off but it keeps on telling me unable to flash those two filesWhat about the zip file signature verification, did you make sure that it is turned off?
Thank you for your help I hope I'm not being a pain in the buttYea its turned off but it keeps on telling me unable to flash those two files
