I need to disable voodoo in order to get the Obsidian ROM. I already tried getting that ROM without disabling the voodoo and i had to reformat my whole phone, so I want to get it right this time.
when changing from one rom to another you need to completely wipe your phone as it will brink probably everytime. disabling voodoo will work sometimes when you update the current rom you are on but i have bricked mine doing that also. but anyway to disable voodoo you make a folder inside the voodoo folder and name it "lagfix-disable", at least i think that is the correct name, and restart your phone, it can take up to 15 minutes for it to restart
The application TwLauncher (process com.sec.android.app.twlauncher) has stopped unexpectedly. Please try again"dumpstate_app_201012270207_com_sec_android_app_twlauncher.log has been saved. Use *#9900# to copy out log.
I got that message can u PLEASE help me. I cant do anything with my phone and it just keeps saying that and i cant click anything PLEASE HELP.
