Hi all.
I am on Orange (UK) and now able to "roam" to a T-Mobile signal. With this in mind I would like to be able to show which network I am using on my home screen but can not find a way of doing so.
Does anyone now of a setting or app/widget that would do this for me?
TIA
I have seen the "Orange T-Mobile" and I know about it showing on the Lock Bar and notifcaition bar when dragged down, but I would like this to be shown on my home screen as that's what I use most of the time.
But thanks for the reply.
Yes, but it's working in the same way as "roaming", right down to putting up the roaming flag in the notification bar and blocking (GPRS) data access when on the partner network if you have data roaming disabled. It also won't hand over calls between the networks, so if you go out of coverage while on Orange your phone will connect to T-Mobile (if available) but the call will drop.personally i wouldnt roam as T-Mobile and orange have released there networks to each other.
If your on T-Mobile and dont have a signal - your phone will automatically use the Orange network - without roaming and vice-versa.
Thats more than likely what the Orange-T-Mobile network name was.
Interesting - I do. Weird....When roam from Orange onto Orange T-Mobile I dont get the R
