Help how to do 2 gmail accounts with 2 icons
brilor04
Member
searched the threads and couldn't find anyhing regarding this. I have 2 gmail accounts and want to have 2 icons on my home screen and not have to keep going into gmail and swapping back and forth to each account. Is there any way to do this?
Here's how I do it:
I use Gmail Unread Count.
It allows you to set up widgets to each email account when you add it your home screen. This way you also get to see how many unread emails you have in each account. It allows you to name them differently too. The only thing I've found is that to make sure you don't end up back in the last account you left is to back out of it each time using the back button rather than the home button.
Hope that helps.
I believe you can only have one GTalk account using the default app. If you want a second one, you would need to get an IM app such as eBuddy, Palringo, Nimbuzz, etc.
I use ebuddy for this. Works fine. Can check messages and whatnot. I just wish you could port multiple gtalk accounts to the same number.
Is there any way to get latitude to use a different gmail account? The account I have I use for email, but none of my friends have this account, it's for "important" email. I have another account with my friends and latitude, but I don't want mail notifications for this account. Is there any way I can do this?
If you're referring for Google Maps only, you can click Menu, More, Switch Account if you have more than one Google account synched.
