Help how to do hard reset on s5690 xcover
I forgot password to unlock the screen on s5690 . I need to do hard reset.how to do hard reset on s5690 xcover
tnx
Same happened to me a while back :) ... i have bought another phone :))
I don't think it's possible to get thru that stupid screen lock :)
I mean without loosing your data :)
Because if you wipe and reset to factory no codes will bother you again :)
If you turn of (power down) the phone; For example: force remove the battery. When you start the phone next time, you can go into the recovery mode on Samsung Galaxy xCover GT-S5690. Here is how: Universal Gingerbread Root & Unroot 2.3.3 -> 2.3.7+
You have an option here (in recovery mode: wipe data/factory reset) to reset the phone, and then the only password you should need is to the SIM-Card.
Now the phone is as when you bought it :)
But have in mind that you are going to lose all you internal data on your phone. Are unsure if you loose data on your MicroSD card, but I do not think so :) [99,8% sure that you don't loose data on your MicroSD card]
