Root How to do sdf?
I downloaded Rsd lite
and ran it but it showed that error occurred, and failed.
How can I run it?
After downloading software, it seemed to run as some MODE...,
and It failed since then.
The screen went black and the green light turned on.
volume buttons+ turn on Droid-> RSD Lite-> show device-> Click-> ...-> vrz 810_something...
Isnt this wrong way??
How can I unroot my phone? It is not working now.. :(
It freezes at motorola logo.
It's actually called "SBF". (Please dont take my correction as rude)
Just follow these instructions: (credit to:Droid X)
Windows Instructions:
  1. Download RSD Lite (credit to MyDroidWorld)
  2. Install the RSDLite 4.7 program by double clicking on the program.
  3. Move the pst_flash.ini file into the following folder --> Program Files/Motorola/RSDLite
  4. Install the drivers that apply to your Operating System.
  5. Unzip the SBF into a folder. (Download Above)
  6. Open RSD Lite and find the UNZIPPED SBF
  7. Put your Motorola Droid X into bootloader. (turn phone off and hold volume down and the camera button while pressing the power button)
  8. Click start and sit back.
Note: after the flash will need to boot into recovery (hold volume down and the home button) and wipe data and cache.
It's been awhile since I've had to do my SBF, but I believe RSD has drivers 4.8 out now.
