How to empty bin in home screen
mathi
I have added and deleted many icons in home screen of my I lg optimus P500. Now I can't add any icon it says no space. Help!
Its always good to keep the homescreen as clean as possible. Just pin the apps that you use alll the time.
Anyways, do a long press on the icon that you want to delete and after a sec youll see a bin kinda symbol on the top of the screen. Move the icon into that; should solve your problem.
ALso do a system clean and a cache clean using apps like Android assistant!
I need to empty bin kinda icon. Thats why there is no space. Pl suggest.
Will the factory rest delete all applications both in phone and sd card or only personal data will be deleted?
The screen is divided into several slots for icons and widgets. Some widgets take more than 1 slot. If there are any slots free, you should be able to add app shortcuts or widgets. Did u try long pressing the home screening and adding from that menu?
Factory reset will delete everything - your apps, app data, personal data, settings, contacts, messages, etc. and the phone becomes the same as when we first turned it on. Moving an app to SD card does not mean it is backed up. This is because only a part of the app is stored on the card, and the remaining part is in the phone memory.
Like i said, please try a cache clean and system clean using android assistant.
I tried cleaning caches and system clean but it doesn't empty the bin, still my home screen doesn't have space after deleting the items in home screen. Please help
