how to enable hdmi on wrap :)
xxpako
i found a way to enable hdmi on the wrap i tested and it works not sure how to get to it but is in the settings of the qualcomm app on my launcher i just press the home screen and choose shortcuts then activities then choose qualcomm settings is going to create a shorcut to the qualcomm app settings built on your phone click the shortcut you created then go to hdmi display options and enable it and thats it now should work whit your tv i have holo launcher hd :) :)
there is a lot of cool settings on the qualcomm settings like enable dual microphone enable auto answer for calls
thats awesome, im gonna have to start including qualcomm settings in my future releases... if i ever manage to make any lol
ok so there is no setting available in cm10.1 that i can find that would make it connect to hdmi as a mirror but it may just work out of the box with the right application
this is a setting for your buildprop or something that can enable hdmi output, though im not sure if it will actually enable anything. if someone wants to try it out though and it works i will try to create an option for it in settings or make it auto fire when hdmi is plugged in
com.qc.hdmi_out=true
see what you guys can find out, sadly i dont have an mhl cable so i cant test on my own but if we can figure out how to make it work in at least one of the source built roms(jellybeer, blackbean, cm10, cm10.1, pacman, aokp) i should be able to add it into our source to enable it across the board
once you enable hdmi on the qualcomm settings stays on even if you turn the device off and is automatic i think when the cable is not pluged says hdmi not connected on the resolution option and when i plug the cable to the tv it gives me options for the resolution you just need to set the resolution one time. for what is that prop for ?? i have no problems leaving it on my phone works same as before. by the way i have superR's stock rom and i changed the boot animation from the rom CyanogenMod 10 from junkie2100 i like more junkie's rom cuz is jellybean but superR's solved a problem i had with the front camera upside down and everything works nice work on your roms guys like your work
ok i think i got it you mean you wanna use that prop on your rom to see if enables hdmi on your rom if i have time later i test it if it does something :)
Wtg.. I love seeing a real tip by the OP prefixed "Tips." ;)
right, but i wanna know what the launcher does to access it... is it a global variable such as that property i mentioned earlier being enabled? or is it a program specific thing? because if all the program is doing is modifying a global setting then it can be enabled in any and all launchers on any rom
basically if you can figure out how to enable it in cm without installing a new launcher over trebuchet thats great but i dont think there is a way to do so. im trying to make sure that it can be done from a fresh install
mmm the launcher is only to make a short cut to a program in specific that is just enabled im gonna check is something changed on the prop or in the settings
damn, sweet that works
so can someone with an mhl cord try that on cyanogenmod or one of its variations? or even on stock rom see if just adding that to the buildprop and restarting the phone will enable it
I'm using ROM Toolbox and the build.prop option was already in there and enabled. So maybe it's just an unlisted feature. I don't have the cable so I can't officially test it.
huh, so it is on stock rom... yea i cant test it either unfortunately. basically what we really need to do is run a logcat output and see exactly what happens when you turn the option on and off
