Codegerm
Android Expert
This will allow your Samsung ROM to use the "bootanimation.zip" to allow you do custom boot animation easily. According to the post, it should work in most any ROM that doesn't already support it. In your CWM recovery you will flash the file "Bootanimation4U.zip" from this post:
http://forum.xda-developers.com/showthread.php?t=2063280
After that your phone will now support the ability to play the bootanimation.zip that you push to /system/media. I can confirm this is working on TW Jellybean (GB27/GC01) and it should work for ICS also.
Here is a link to some animations you can try out:
http://forum.xda-developers.com/showthread.php?t=2197865&highlight=bootanimation+zip
For these animations I did it the manual method of opening the archive and copying the bootanimation.zip to /system/media on my phone (also made sure file permissions are rw,r,r)
As always: Make sure you have a nandroid backup before flashing anything in recovery.
That practice should be followed no matter what you are flashing.
