Help how to erase bookmarks
I've got a lot of bookmarks set and don't know how to erase them. Please be specific for a true noob
Thanx :confused:
Select BROWSER>MENU>BOOKMARKS. Then long press on the bookmark that you want to delete & a menu will pop-up,giving you the option to delete, among many other options.
Thanx :confused:
KOLIO gives you the answer to that, unkledude. I was just curious which browser you're running, if it's the stock one that came loaded with your phone, or are you running Dolphin or Opera or some other one (slight differences in bookmark manipulation in some browsers ;)).
