droidfan1
Really simple fix here. No matter what I did (disabling LTE, etc) my battery life was atrocious.
Dead in 7-8 hours, and that is with the extended battery!!
Easy fix? Turn Wi-Fi ON. Seriously. Just turn Wi-Fi on and leave it on.
For whatever reason, this works. It's been 6 hours, and my battery is at 64%. Instead of 10% or less.
Thank me if it helps you. If it doesn't, well, it worked for me!
EDIT: Another thing to try: App called Juice Defender. Works great.
https://market.android.com/details?id=com.latedroid.juicedefender
Download it here. Use either Balanced, or Aggressive (I use aggressive).
Really helps battery life if you are feeling upset about the Gnex's poor battery life. (For some).
