Root How to flash 2.2
Im new on this root/flashing roms. I have a samsung fascinate i would like to up date it to the 2.2 or 2.8. To make my phone work better. Iv seen guys that have a htc from sprint evo. He put some different roms and stuff on his phone and its very fast and cool. Could some one give me step by step instructions on how to flash to the 2.2 or better. what goes where on the odin
thanks
Here's the link you want:
[Odin] Full EB01 Froyo leak, packaged ROMs w/root and new clockwork **UPDATED**2/11 - Droid Forum - Verizon Droid & the Motorola Droid Forum
Download the file and flash it under the pda section in Odin. Everything's included...rom, radio and kernel, but you want to run voodoo here's a link for the EC10 kernel:
[KERNEL][3.21.2011]EC10 Kernels - xda-developers
There's also one for non-voodoo too if you don't want to run it, but I'd suggest it since non-voodoo is a dying breed on these phones.
Super Clean version 2.9 - EB01/EC16 Froyo leak root+Froyo Clockworkmodwith MALWARE protection
RIGHT CLICK AND SELECT EXTRACT HERE THE .rar file AFTER DOWNLOADING AND BEFORE USING(How to extract in post #2) -->EC16SC29_DXC.tar
WARNING: NO DATA WIPE MAY CAUSE FC IF COMING FROM ECLAIR, FULL WIPE IS RECOMMENDED
Super Clean version 2.9.2 - EB01/EC10 Froyo leak root+Froyo Clockworkmod with MALWARE protection THIS VERSION DOES NOT WIPE DATA (TESTED by Standupdad Please thank him)
RIGHT CLICK AND SELECT EXTRACT HERE THE .rar file AFTER DOWNLOADING AND BEFORE USING(How to extract in post #2) -->EC10SC292x_DXC.tar
Can someone please tell me the diffrence of these two. Iv down loaded the first one but dont know what these do
thanks
thanks
[ROM][3.23.2011] Superclean 2.9.2 EA15/EB01/EB16/EC10 Based - xda-developers
Read the 2.9.1 and 2.9.2 changlog sections to see what was changed since 2.9
I'm new to all of this, how would I load the EC10 kernel? I used Odin to load the SC 2.9 EB01/E16 build listed in the above link, but I'm having trouble finding a walkthrough for loading kernels.
They come as a zip package which you flash in Clockwork Recovery (hold the power button and choose recovery from the menu--assuming the phone is on). Once in recovery, select "install zip from sdcard" then "choose zip from sdcard." Navigate to the zip file, select it, and let it do its thing (which will include strange looking blue lettering flashing across the screen...this is normal). Flashing kernels is pretty painless.
