Root How to Flash 5.9.905 GB, 6.7.246 ICS or 98.72.22 JB with Rsdlite
I just followed the steps for flashing back to 5.9.905 modified. Everything worked as expected but when I touch the green man on my phone an error message saying" Sorry! The process com.android.phone has stopped unexpectedly. Please Try Again.
It has a Force Close button that I can choose but everytime I choose Firce Close the error pops up again i a few seconds. Any suggestions? I'm at a loss and am new to this process. I did load leak 6.7.232 on August 30th so I have a little experience but that's it.
Bondad
Had to make an account to thank you Dfib. I realize this is a conglomeration of many works but you compiled it nicely and it fixed my Bionic issue (unrooted with SU and missing the required bloatware for ICS update). Thanks for taking the time to compile this all and help so many.
Bondad
The reason its force closing is because you used the modified 5.9.905 and it saved the ics data which does not jive with gb. You need to use the full 5.9.905 fxz and wipe all your data to get rid of the fc issue
just an FYI
Hi Dan,
This email is an automated notification from Dropbox that your Public links have been temporarily suspended for generating excessive traffic. Your Dropbox will continue to function normally with the exception of Public links.
This suspension is temporary (3 days for the first time).
pm me if you need one of these files
i was running leadked ics .232 and in an attempt to get the ota ics update i flashed back to .902 modified. now i'm bricked. is it because of the modified? i just saw this in another post: "The reason its force closing is because you used the modified 5.9.905 and it saved the ics data which does not jive with gb. You need to use the full 5.9.905 fxz and wipe all your data to get rid of the fc issue" If this is the issue then how do i fix it? all the posts about unbricking your phone that i've found are like a year old and take you back to some version of gb that i never even had. i can get into the fastboot screen. can i just flash .902 stock/not modified?
you need to use a full fxz when coming back from ics to gb. here is a link to the 6.7.246 fxz. It will put your phone on ics ota with a lean slate. flash just like it you did the modified .902
http://sbf.droid-developers.org/cdma_targa/VRZ_XT875_6.7.246.XT875.Verizon.en.US_CFC_01.xml.zip
If the links are not working let me know because I might have just got banned from dropbox. I am trying to figure it out now with them.
Thank you for the steps! Fixed my bionic that got bricked due to accidentally hitting OK to OTA update when batt was < 5%.
I found working files on
http DAT androidforums DAT com SHLASH bionic-all-things-root/540725-droid-bionic-fastboot-fxz-files DAT html
Links are Disabled. If you can do anything to get these links back up that would be great. thx...
I am trying but You need to understand all the files you download, not just from my thread are hosted and most of the time on a paid site. Most of us pay for it out of our own pocket and they have limits on how much bandwidth can be used per day, week or month. Every time we reach that limit the accounts are suspended, banned or closed for a certain amount of time or indefinitely and we either have to wait for them to be released or find and pay for a new host. I have used so many different host this year it is crazy. I do this because I want to help the community that has help me when I started. We that said they will be available when dropbox release my account because i don't have time to transfer all the files and post the links to the new host, until then anybody can PM me and I will send them a link to what they need.
Hi, noob here. Where do i find the 901 file to flash? I tried using the vulnerable_recovery_only_RAMDLD90_78.sbf file that popped up but i get an unable to retrieve interface handle error
Yes i have a bionic. Trying to unroot so i can get the ota update its been trying and failing to install. That was the file rsdlite automatically pointed to
