Root How to flash custom ROM?
randy_c
I bricked my phone .. rookie :-) I just wonder if you can spend time posting instruction to flash phone to GB 2.3.3 and cognition 5? I brick my fricking phone.. all I have now was phone connect to PC everytime turn it on. Ordered Jig from ebay and hope to fix the problem.:D
Most all ROMs out there on XDA have very specific instructions for flashing. Most are the same from ROM to ROM. Serendipity is an excellent one....check out the website (it have step by step directions - if you follow them to the "T", you should have ZERO problems!): Serendipity - Home
As for 2.3.3 - There are some good ones out there. I just went from Serendipity 6.4 to GR-11 by MikeyMike01. It is still a Beta ROM, but is pretty dang stable and SWEET! Once again, follow his instructions on XDA perfectly and it should go smooth.
