How to Flash LG Optimus 2X to Android 2.3.4 Gingerbread
How to Flash LG Optimus 2X to Android 2.3.4 Gingerbread 20L
Here's How WORKS GREAT..............HOWEVER DO AT OWN RISK........
All things you will need before flashing your LG Optimus 2X:
  1. DOWNLOAD:Download KDZ_FW_UPD_EN.zip for free on Filesonic.com
  2. DRIVERS:http://www.filesonic.com/file/MCCI(r)FirmwareUpdateDriverforMTK.zip
  3. Android 2.3.4 Gingerbread V20L(latest):
How to flash LG Optimus 2X with a kdz file steps: LG Phone Problem and Solution
  1. Download KDZ_FW_UPD_EN.zip
  2. Install B2CAppSetup.exe (if you don
Hello Dear friends, first of all thanks for the step by step explanation...
I have a question: I have updated My phone to 2.3.3
and what is new in version 2.3.4
can you post the change-log for this
Thanks
hello, why cant i upgrade using mobile data? when ever i want to update the phone keeps instructing me to connect through wifi. can anyone pls help?
because the wifi needs to connect to the LG server and the file is far to big to be downloaded, is there a problem with using the wifi on your phone?
