How to Flash Your Transform to Stock
[TheAndroid]
Making your phone stock removes all apps, ROMs [Point Blank ROM, Froyo builds] Root access, and your custom recovery.
Your going to need to download this file named 'full_restore_stock.zip'.
This is your key to making your phone stock. Download the file, plug your Transform into your computer and mount the SD card. Copy/cut the full_restore_stock.zip and put it into 'sdx', and then into the child folder 'zip'. (Also known as /sdcard/sdx/zip) Disconnect your phone and reboot your phone into recovery mode via 'Quick Boot' or manually by turning off your phone and then booting into recovery mode.(Volume down, voice button, power button)
Note. You can just download the file from your phone and put it into the sdx zip folder via a file manager.
Open the console in recovery mode. Press enter and then type 'rfs'. Your phone with say 'Success to format' about 3 times and then boot back into recovery mode. Now go to 'Apply zip from SD card' and apply your file full_restore_stock.zip (Menu, then home to confirm) Now go back to your menu and reboot to system. You will now have a totally stock phone. No custom recovery, root access, or modifications of any kind.
All credit for this goes to Vampirefo on SDX. I just wrote this guide.
So then what happens if I restart my phone when I type rfs accidentally or if my zip is corrupted?
If your zip is corrupted? Unlikely, and your phone would still boot into recovery thus you could still fix it. Same with typing rfs, it would boot to system and probably work for like a day and then you'd have to boot into recovery and fix it. Your just about fool proof.
ok right now im in recovery mode and it has 4 options to choose from
1. reboot system now
2. apply sdcard: update.zip
3. wipe data/factory reset
4. wipe cache partition
not sure which one to choose to restore to stock?
I tried to press enter and rfs but nothing happened.
Dude, you're already stock.
I haven't done anything. I bought this phone used a few days ago, and this icon was on it. But I need to take it into Sprint for repairs and need that icon off first.
The guy you bought it from must have rooted it but was stupid enough to not install custom recovery along with it. You're gonna have to flash back to stock the natural way, but doing this can dangerous if you don't pay attention.
I already posted this on your thread... But since you havn't looked at it here it is.
Download and install the SW Updater Free File Hosting, Online Storage &amp File Upload with FileServe (86,252 KB). This will require you to reboot your computer after it is installed.
2. Download the Kernel/Recovery file SPH-M920_MR1_DI11A_REL.tar.md5
3. Navigate to c:\Program Files\Samsung Electronic\SWUpgrade\Models\Binary and delete EVERYTHING inside of this folder.
Note that in 64bit versions of Windows, you need to be in c:\Program Files (x86)\Samsung Electronic\SWUpgrade\Models\Binary
4. Run SWUpdater and follow it's instructions
I tried typing "rfs" but it said command not found or something. I'm running vampirefo's overclock kernel.
Bump, I need a reply to this since the update for 2.2 is right around the corner. Is there another way I can apply this zip without typing rfs?
Vampirefo made this only with the ability to flash rfs. Also it was smart because if you did something like ext4 it wouldn't be stock and probably would screw up your phone if you did the 2.2 update, if thats what you were wondering. As it stands now this is the only way to do it unless you want to use SWUpdater and all of that stuff.
Why cant you use sw?
when you typed rfs did you press enter first?
and also after typing rfs did u give it a minute or two?
Howd u root in the first place than? Lol.
Well that might be your problem, after u press enter, than type rfs it should say something, im guessing what u saw,than after like a min at most itll say "sucess to format", itll say this three times each time will be on a different command line.
If u see this than it means it worked, so try again but give it a min before u exit.
This is what I did (in steps):
  1. I went to recovery
  2. I went to the console
  3. I pressed Enter
  4. I typed rfs
  5. It gave me an [rfs] not found error
[TheAndroid];2408508 said:
Rosie, would you be able to use SWUpdater from another PC? Even at a library would work.
Wouldn't I need admin rights to install it? I'm pretty sure I wouldn't have those at a public place.
