ackoolness
running low on internal memory and kind of what to start over. I am on me7 using darkslide to root.
** UPDATED ** [Rom Darkslide SG4 VRUAME7 Stock Deodexed] Come and get some.. - Samsung Galaxy S4 ROMs - DroidRzr.com
long route: just flash a stock mdk, root, and follow the steps in the link above to root again. blah, a lot of work.
I have clockwork installed.
Is there a way to format the internal memory? dont worry, I will take out my sd card, so no worries with that.
If there is a way, apparently you can accomplish this by going into recovery then mounts & storage then format /sdcard.
I just want to someone who has possibly done this to clarify exactly what this accomplishes. As in, what does it delete? Does it touch the system files? Root and recovery doesnt get touched? Thanks.
