JimmyTheSaint
While connected to the dock, the tablet's battery remains fully charged until the dock runs out of charge. Is there a way to tell how much charge remains in the dock while docked or undocked?
Dual battery widget from Android market
https://market.android.com/details?id=org.flexlabs.widgets.dualbattery&feature=search_result
I believe all widgets install like that...it's a widget, not an app, so as you found out, you need to drag the widget to your selected homescreen for it to be visible.Oh, for God's sake--I found that tricky mf. I guess the clue is that it's named "widget" and the developer wants you to have a little adventure using it the first time.
Nice widget isn't it...works well and is resizeable too.
