Chrome does not support flash, but if you download flash from Archived Flash Players you can just download a browser that supports it like boat or firefox.Is there a way to get Adobe flash to work with the native browser or Chrome on Android tablets?
All you have to do is open settings, got to security, and enable the ability to install apps from unknown sources. Then go to your download folder and install flash.I downloaded firefox and it did it not let me use flash. I am not too techy. How do in side load it?
I could upload it to a file sharing site and post the link but its really bad practice to post or download from a direct link on a forum because it could contain anything.
If you feel that you trust me then enable Unknown Sources in Security settings and ill pm you a link if you want (that you download and install at your own risk) or ill see if i can find a link to it from the Adobe site later. Let me know mate :thumbup:
I would try to use Samsung's stock browserThank you so much! I downloaded it to Firefox and installed it. But I am unable to see video on Pittsburgh Post-Gazette. Am I doing something wrong?
I really appreciate your help. I would like to ditch my ipad if I can get the note 8 to work.
Try Puffin Browser.
