Help How to get back to phone screen while on call?
kbayer
Ok, you are on a call and you go to check something on the browser... how do you get back to the call screen so that you can eventually use the red phone button and hang up?
I can still talk while I'm browsing. I can go back to "home" and press the phone key again, but that just gives me a fresh start to initiate another call.
I'm sure it's just an easy 1 step process that I'm not seeing...
The Verizon Moto Droid is CDMA. CDMA does not provide for simultaneous voice and data connections. You can only do one or the other. Sorry. Note: you placed this under the Moto Droid Forum.
Yes, you are right. I double checked when I read your response. I could not get the phone to repeat what it did this morning. Droid fluke/operator error...
Thx!
It is possible to talk and browse with the DROID if you are connected to wi-fi.
To answer your question, you can pull down the notification panel and select the phone call from there... it drops you back into the call screen.
