1BlinkGone
Contact me through gtalk
hurtado.christian13
Okay, thanks. I just sent you a request- RB
hurtado.christian13
hurtado.christian13
Sure there is a way, first go to settings/mobile network/access point names, then hit menu then create a new apn and name it what ever you want, under apn paste this (epc.tmobile.com) and save it..
Now you have free tethering.![]()
I did forget to change my wifi widget to connect through my apn, but once I figured that out and changed it, it has worked flawlessly. My wifi usage counter has been stuck at 247mb since employing this trick, even after using around 8gigs and connecting my comp and Xbox, and even my wife's phone since she has a limited plan. Im not sure if it will work with tmobile but i use fox fi
Just download wifi tether for root users from the playstore, and
Press the Menu Button.
Click Settings.
Click "Change Device-Profile".
If you are on Ice Cream Sandwich, choose "Generic ICS".
If you are on T-Mobile, Scroll down and MUST select "Routing Fix".
Tether!!!!
