ok i said 4.1 havent tested on other android version
1 press the home screen for 3 scds select shortcuts
then activities then select hidden menu then select port
is going to create a shortcut for diag mode
click the shortcut and select port on and thats it just flashed prl
and im using holo launche hd
https://play.google.com/store/apps/details?id=com.mobint.hololauncher.hd&hl=en
