how to get old astrid???
adam_hilluk
hey
you may know that the latest updates of astrid are a bit naff and have removed some features.
Due to this the dev has put a link on the d/l page on the market to get the old version. I typed this is on my laptop and d/l but now i dont know what to do to get it on my phone...
can anybody help me please??
cheers in advance
You need to hook up you phone to PC in storage mode and copy the apk file onto your SD card. Then you will need a file browser app on the phone such as "Astro", browse to the correct place on your sd card where you copied it to and it should give you the option to install it when you press the file.
BTW you will need to have ticked "Unknown Sources" in Menu --> Settings --> Applications
hey
you may know that the latest updates of astrid are a bit naff and have removed some features....
A BIT? How about the difference between the pusycat dolls burlesque show and the pusycat dolls as performed by 12 clones of Larry King overdosing on cold medicine?
I'm loving this advice on how to do it, but right now i need WHERE to get it. I need to DL a copy of the old file somewhere. Anyone have any ideas?
