Help How to get Titanium Backup to use SD card?
Mysteryman
Member
I have a Galaxy S4 and, like a lot of other people, am now finding it is low on internal memory.
So, I set about the process of removing some of the bloatware that Samsung have included on teh phone and that I do not use.
First step was to root the phone - no problem.
Second step was to install Titanium Backup and backup apps/data before I start to delete stuff.
However, this seems to create the backups on the internal memory and, thus, makes my situation worse!!!!
Can someone tell me how I can persuade Titanium to write the backups to the SD card I have installed, please?
Thanks
OK, have created a folder called TitaniumBackup on the SD card then gone into the "Backup folder location" option as mentioned.
I can select the folder, but, it says it is "not writeable" - any ideas how to fix this?
I think you have to let TiBu create the folder which I hope you can specify in the settings.
There's a thing where Android changed how SD card permissions / security for write access was changed in 4.x but subsequently relaxed a little bit--but it sounds like your currently affected.
There's a thing where Android change how SD card permissions / security for write access was change in 4.x but subsequently relaxed a little bit, but it sounds like your currently affected.
Yeah, that was my thought if he was on KitKat....
Whelp, that blows my theory outta the water.
It looks to me that in the Preferences - Backup folder location then you need to select an existing folder for it to use.
Grrr!
Is the path correct?
Here is my screenshot:
Use a root file manager to manually copy any existing backup file from the current location in internal storage, and paste it into the new one you created on the SD card. Titanium Backup won't validate the folder unless it sees at least one backup in it. I recall having to do this when I set mine up.
