Help How to hide audio books from music player?
Hi, does anyone know how to do the above? I have a dedicated audiobook player, so I'd like my music player to ignore these files... any ideas?
Thanks in advance
well.... just make playlists with the music u wanna listen to and you're good.
its very simple to do, you dont even need an app. for that
Put a dot in front of the audiobook folder (e.g. ".MyAudioBooks").
Then the stock media player will not see the audiobooks.
EDIT: If you don't want change the folder name: Make a file named ".nomedia" and put it in the audiobook folder. Same effect :)
EDIT2: If you use a file manager (e.g. EStrongs File Explorer) for the implementation, make sure the media player has indexed the changes at or in the audiobook folder.
I use the free app SDRescan for that.
Harry
