Is there any way to increase external speaker volume? The TB in store was quite loud but I cannot even use as hands-free in car for mine. Can this be fixed by SW update?
Design of speaker location is almost as silly as disabling 4 of the 8 gb of internal flash
added:
The ambient sound in your car (unless your car has great external insulation and windows always up) will usually be louder than in a store. Joking aside, the stand does muffle the volume.
it's funny how ahead of the game the OG droid was. it sopiled me with simple things like ridiculously loud speaker volume and an awesome led notification light. the only thing you can really do is when you're playing music, set it to srs. but it only effects music play back maybe an update will make it louder *fingers crossed!*
