Root how to install custom roms on motorola droid x gingerbread
Kevin123
Member
Hi can anyone tell me how to install custom roms on a Motorola DROID X? I just got it rooted and now want to add in roms but don't know how so can some one help me and give step by step instructions to add in roms
Kevin
you need to download droid x/2 bootstrapper from the market
$2.99 <-- you need it or you cannot install custom roms
open droid x/2 bootstrapper hit bootstrap recovery
allow super user access
hit ok for success
hit reboot recovery
scroll with volume rockers to wipe data/factory reset
select it with the camera button, then confirm it
scroll with volume rockers to wipe cache partition
scroll with volume rockers to install zip from sd card, or something like that
scroll to choose zip from sd card
find the rom you downloaded
install the rom
once install is finished, hit your back button
then reboot the phone.
your done.
any other questions let us know
I can make you one up... but you have to be premium to add a graphic to your signature, even if you are a guide.
trophy... just send me a PM and when I get a free second I will make you one up. Still rocking the Type 95 and ACR!!!
I just rooted my droidx running 2.3.4, system 4.5.621. I want to install custom ROM.
I see a lot of info about the ROMs and confused. Please guide me to install the correct ROm.
