Root How to Install Quattrimus?
jtragna
Member
The Developer didnt put how to install on his post. How do you install it, I forgot how to install a custom ROM, i havent done it since January! I forgot what i have to Wipe, How to Flash and what-not, please tell me so other people not fimilar or that forgot will also have help with this!
Its the same way as BACKside?
The only difference between methods for installing ROMs should be if you need to flash gapps.
Wipe cache
Wipe dalvik
format data
format boot
format system
format cache
format dalvik
install from zip -> ROM
install from zip -> gapps (if not included in the ROM)
install from zip -> flashable theme
reboot
Ok i did it thanks everyone! And with this specific ROM you DO NOT need to flash gapps, it is included with Crynogen Mod 9
