I realize that the device is meant to show a widescreen "sideways" view when it is turned sideways, but my phone seems to be doing this every time my hand that holds the phone turns a little bit. Is there a setting that I can change the sensitivity of whatever is telling Android to rotate the screen display 90 degrees?
I have read that there are apps that can do this, or that I can control it on an app by app basis. I do want this feature, but I just want to control the sensitivity, so the screen isnt rotated on any app until I actually rotate the device itself (almost) 90 degrees. Can I change the setting within Android itself, or do I need to install an app.
