ParinoidAndroid
Your source is urban dictionary? Get out of here you clown. It's not proper english. I win.
PEACE
It was a joke. you fail
PEACE
PEACE
You should drain your battery down all the way every once in a while for the phone to calibrate how much capacity the battery has. Please read up on lithium batteries before ....You don't want to drain the battery all the way down, use it as you would normally. In fact draining it all the way down does some damage to the battery and you won't get as much life from it afterwards. Please read up on lithium batteries before you continue to ruin your battery.
Let's just say you're both right. However, Li-Ion are not meant to be constantly drained and reused, drained, and reused, drained, and reused. That was the old Ni-Cad batteries; Li-Ion do not benefit from it, they'll get damaged. Many ask, "Well then, why do Li-Ion batteries lose charge over time (and why notebook batteries are notorious for losing charge and dying out quickly)?"You should drain your battery down all the way every once in a while for the phone to calibrate how much capacity the battery has. Please read up on lithium batteries before ....
I need some tips on how to kill the battery so I can cycle it to optimal usage. Thanks. I have the display on 30 minutes (max) and Pandora streaming music. I have gps, wifi, bluetooth, and google sync on as well.
Anything else?
Robo Defense destroys batteries. theres a free trial on marketplace
PEACE
PEACE
