How to load homepage without going to bookmarks?
Tomjh99
When I am using the brorwer and I go to a website, and after I am done looking at whatever it is I looked at I just just hit the home button and it take me out of the browser. Now when I go to use the browser again it pulls up with the last website I was looking at. I hit the menu key and usually have to tap bookmarks and then tap my homescreen bookmark. Is there an alternative way to load my homescreen ?
If using a task killer, kill the browser and the next time you enter the. browser it'll be your homepage.
I know of no other way to do it....
I usually back out of the web browser. The next time I go into the browser, I'm at the home page. Or as stated above, use a Task Killer
If you have some real estate left on your home screens,try using a bookmarks widget. My left of center home screen has my bookmarks, and that's always how I enter the browser. Just set your home screen as the top entry in the bookmarks widget.
I noticed this as well. I created a shortut icon to a bookmark of my homepage and use it to start the browser. This works great.
Jack
On the home screen, long press and select Shortcut. From there select Bookmark. It will show you a list of your bookmarked sites. I select which site I want and it sits right on the "desktop" so when I click it I open Google.com (or what ever home page you wish it to be)
Also if you use Dolphin browser, you can create a gesture (pattern to swipe on the screen) that will take you to your home page.
