Just make a directory called "ringtones" on the SD card and put them in there... they'll all show up when you go to select your ringtone. This info is also in the tips and tricks sticky, or maybe it's the FAQ one... I forget now.
anyone know of how to clip part of the mp3 for the ringtone? There are certain songs I want the chorus instead of the beginning of the mp3. Take Crazy Train from Ozzy for example, that's ok bc the first few chords are what I want but there are others I just want the chorus.
Yes go to contacts --> select a contact --> menu --> edit contact --> and swipe to the bottom and select ringtone. Quite a few steps but it allows you to set it for each one.The problem with this is you can't set them as the ringtone for individual people. Any idea how to do that?
Thanks! I figured I had to go and download an app.Download ringdroid from the marketplace. You can do it right on the phone.
