Root [how to] lock/unlock your bootloader without htcdev(s-off required)
scotty85
Extreme Android User
this thread will let you unlock your bootloader without htcdev,or let you change your hboot watermark from relocked or locked back to stock.
originally,we used a zip file flashable in recovery. i have found it to work on gsm devices with 1.44 hboot and CW recovery. it did not work with twrp. if the following is too scary,feel free to test the zip files. that thread,info,and downloads can be found here. since not all recoverys are working,these values can be changed with simple adb commands.
advantages
-no hassle with htcdev,tokens,or unlock codes
-no submitting your phones personal info to htc
-the ability to get back to 100% stock without any visual traces or records of having been s off or unlocking your bootloader.
you do NOT need to downgrade your hboot. this simple adb command works without any scary hboot downgrades.
*you must be s off.
*you must have superuser installed
read this:
this will not work if your s on. its not a way to magically unlock
the usual disclaimers:
use this info at your own risk. if it melts your phone into a little pile of aluminum goo,its not my fault.
credits
-beaups for schooling me on echo comand protocol
-strace for originally discovering the location of the lock status flag(check out this thread for more info)
-kdj67f for fearlessly testing on vzw m7_wlv and putting up some screenshots in post 2. thanks!
-matthew0776 for fearlessly testing for sprint m7_wls
*i dont have m8. let me know if it works and ill add you to the credits.
IF you are an advanced user with adb/fastboot set up and some basic knowlede of the cmd window,you can skip to #2
1)set up adb(windows 7 and older)
-download this file
-install drivers: if you have htc sync installed,you should allready have drivers. if not,you can install htc sync,or install these modified htc drivers from revolutionary (driver mirror)
-unzip your miniadb_v1031.zip file. this is native funtionality in windows 7. you otherwise may need a utility such as "7-zip" to extract,or unzip it. place the unzipped folder onto the root of your C drive on your PC. root means the top level,not inside any folders. so just copy and paste,or drag and drop the folder onto C with everything else that is there. you may want to rename it to "miniadb_m7" since youll be putting some device specific files in here.
-open a command window. on windows 7,click the start bubble in the lower left and type "command" in the search box. xp i believe is similar or the same. doing this should open a small black command window.
-change to your miniadb_m7 directory. type the following at the prompt in your cmd window:
cd c:\miniadb_m7
your command promt should change to "c:miniadb_m7>" provided you: 1)unzipped the miniadb_v1031 zip file,and 2)put the folder on your c drive,and 3)entered the name of the folder correctly ("miniadb_m7" in this case)
-now make sure usb debugging is checked in developer options(you will need to turn it on first),and plug your phone into your PC with a usb cable
-make sure your phone is being recognized- type:
adb devices
if your drivers are installed correctly,this should return your phones serial number. you should hear the "found device" noises when you plug your phone in. if it starts installing drivers,wait for it to finish before typing the adb devices command.
if you get your serial number back,then enter this command:
adb reboot bootloader
this should take your phone to the "fastboot" screen,wich is white with colored letters. this is one mode of your bootloaders interactive modes. at the top youll see fastboot devices as confirmation youre in fastboot.
now enter:
fastboot devices
again,this should return your phones serial number. you should hear the "found device" noises when you plug your phone in. if it starts installing drivers,wait for it to finish before typing the adb devices command.
if you get your serial number back,you can enter the following to boot back to the phones OS:
fastboot reboot
and now,youve installed adb/fastboot and tested youre phones drivers. if at either spot,you have trouble and dont get your serial number back,there is some sort of connection issue. use these steps to troubleshoot:
troubleshooting connectivity issues:
-try a reboot of the PC
-try different usb cables and ports
-dont use a usb hub
-dont use usb 3.0
-make sure nothing capable of comunicating with the phone is enabled and running. htc sync,pdanet,easy tether,and even itunes have all been known to cause issues.
-windows 8 has been known to have issues. try a windows 7 or older machine
failing the above,
-i use these drivers for fastboot and adb(donwload and run as admin): http://downloads.unrevoked.com/HTCDriver3.0.0.007.exe (mirror)
failing that,try manually updating the drivers in the following manner:
-put the phone in fastboot mode(select fastboot from the hboot menu)
-open device manager on the PC
-plug in phone,watch for it to pop up in device manager.
-update drivers with device manager,pointing the wizard to the extracted
driver download folder from above
note that you can check the connectivity of the phone,and make sure drivers are working by in the following manner:
-open cmd window. change to directory containing adb/fastboot utilities
-adb with the phone in the booted OS,usb debug enabled,enter:
adb devices in a cmd window
-fastboot with phone in fastboot,enter:
fastboot devices in cmd window
in either case,a properly connected phone with working drivers installed should report back the phones serial number.
this process,in your cmd window,should look something like this:
Code:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Scott>[COLOR="red"]cd c:\miniadb_m7[/COLOR]
c:\miniadb_m7>adb devices
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
List of devices attached
FAxxxxxxxxxx    device
c:\miniadb_m7>[COLOR="red"]adb reboot bootloader[/COLOR]
c:\miniadb_m7>[COLOR="red"]fastboot devices[/COLOR]
FAxxxxxxxxxx    fastboot
c:\miniadb_m7>[COLOR="red"]fastboot reboot[/COLOR]
rebooting...
finished. total time: 0.037s
c:\miniadb_m7>
2)reset your "lock status flag"
to LOCK your bootloader,enter the following:
adb devices
adb shell
su (if needed to get a # prompt)
echo -ne '\x00\x00\x00\x00' | dd of=/dev/block/mmcblk0p2 bs=1 seek=33796
(i would very strongly recomend you copy/paste this)
exit
(exit a second time if you need to to get back to a normal > prompt)
verify you are now locked
_____________________________________________________________________________________________
to UNLOCK your bootloader,enter the following:
adb devices
adb shell
echo -ne "HTCU" | dd of=/dev/block/mmcblk0p2 bs=1 seek=33796
exit
verify you are now unlocked
*i have tested this on my gsm htc one. if someone wants to test on vzw,ill add you to the credits :)
(yes this is m7. i just got my m8 :D)
other useful threads:
remove tampered banner: *coming soon
change mid without an eng bootloader: *coming soon
This is really slick! Pretty work. Per your note...the usefulness of relocking is to remove the evidence that you unlocked your bootloader...any other benefits?
Hey Scotty, Firewater requires root before it will work, so you need to HTCdev unlock the bootloader prior to getting s-off. At least for Sprint this is the process.
I know the Verizon variant has Weaksauce for Permroot, which can get Firewater to work without unlocking, but is there any way for the other variants to get this without unlocking the bootloader?
Or is this just the code needed for switching the bootloader flags regardless of how you achieved S-off?
Obviously I get confused easily. :p
the biggest advantage is to get back to a stock,locked status if a warranty is needed,since only relocked is possible with fastboot oem lock.
other than that,its just an easy way to flip back and forth without the inconveneince of using htc,flashing the token,losing data(since htcdev does a factory reset),etc.
one can easily leave the bootloader locked,while s off,and still install anything they need via ruu mode and a properly made up zip file. however,if someone wants to use the fastboot flash or fastboot boot command,they could easily switch to unlocked and then back again,rather than messing with making up a zip file. its a matter of personal preference,really.
i personally just leave my bootloader unlocked. however,some devices are promotions need the bootloader locked in order to get the promotion,or for certain hardware to work. for example the extra google drive space,dropbox space, etc. also the one max has to have its bootloader locked,and NOT displaying the tampered banner in order for its fingerprint scanner to work. folks in these situations can leave the bootloader locked,and unlock momentarily if they wish,and lock right back.
its unfortunately not another way to root,its an after-the-fact convenience,and a "get back to 100% stock" tool. hope that clears it up some :D
Absolutely my friend!! :)
Once we get RUU's we'll be able to run one, then unlock the bootloader without using HTCdev if you have S-off. Very cool! :)
Thanks Scotty! Have you given Viper a whirl? I was pleasantly surprised. I strangely like Sense 6.0. Wasn't a fan of sense when you and I were running the TBolt. But, i like this version. The customizations are extensive but useful.
I've run viper on other handsets,its a good rom,especially if you like lots of options to customize. Haven't run it on the m8.
Sense 6 is ok. Sense 4 is the only one I've truly liked,and I feel 5 and 6 are heading the opposite direction- stuff is becoming more blocky and 2 dimensional,deflintely less elegant in my humble opinion. I will agree its better than anything older than sense 4 and I still tend stay stock so I can have zoe and boomsound :cool: I hate to admit,blinkfeed has grown on me as well :o
