Help How to make texts longer? Please help :-(
youghal88
I had a samsung tocco lite and it was brilliant for sending long texts without a limit and because i have free texts i had no worries sending a text 4 messages in length. I switched to the Galaxy Europa and I'm limited to 3 messages in length anything longer and it automatically turns into a multimedia text. is there any way to make my Europa similar to my last Tocco Lite in regards to no text limit?
I guess that you are using stantard application for sending txt msg?
So maybe if you will get some new application from the market it will fix the problem. But im not sure.
