Help How to make WIFI from my PC (using enternet cable) ? Windows XP
Batreky
Member
Dear all :),
How to make WIFI signal from my PC who (using internet cable)?
System :Windows XP
Please Guys I'd appreciate if u can help me with making an wifi signal out from my Desktop by whatever (USB Dongle or PCI card) to use it with my Desire HD and won't any problem about my Desktop internet when using this wifi
Note : I want this help cause my modem is out of my area too much space that's all
Thanks in advance & Best Regards,
BaTreKy
I'm not clear what you're asking...
You want to connect your dhd to your pc via wifi without the use of a router?
He wants to turn his PC into a Wifi hotspot so he can connect his DHD to it.
Go into Control panel
Open “Network Connections”
Right click on “Wireless Connection” and click on “Properties”
Click on the “Wireless Networks” tab and select the check-box which says “Use Windows to configure my wireless network settings”
Under “Prefered networks” click “Add”
Type a name in “Network name” text box
Select “Shared” from the options under “Network Authentication”
Under Data encryption select “WEP” and type in your password in “Network Key” field and now click “OK”
Now the new HotSpot should show in the list of preferred networks.
Click on the “Advance” button and select “Computer-to-computer (ad hoc) networks only” and press close
Hit “OK”, we are done with the wireless connection properties
Didn't those work?
Didn't those work?
I mean MY PC has internet by Wire from my modem who out of my area Like (300 Meter) and I want something like USB (Dongle) or So to connect it to my PC and make a Signal in my Room To use it with my Desire HD WIFI .. Is that Clear Guys to understand me :confused:
About your Way Mr.El Presidente I didn't find anything have to connect it to let my PC make a WIFI signal ?
It should still be the same procedure. Have you enabled Internet Connection Sharing on the PC?
Here's a guide with pics -
Making the Wireless Home Network Connection in Windows XP Without a Router
See this from your Link :
1.
The first step will be to install an 802.11b wireless card in the main computer and configure it as a computer-to-computer (ad hoc) wireless connection.
2.
The second step will be to install a wireless card in a second computer.
She said from PC to PC and must 2 wireless cards installed ? I want from PC to phone ?
1.
2.
Pc to pc isn't to be taken literally, your pc has the ability to be seen as an AP (access point/hotspot), at least it can with a dedicated pci wifi card.
Your phone will then have something to connect to via wifi.
I don't know this adapter's specifics, so can't say whether it will or won't work for you.
I just know my pci wifi card comes with the ability to be an AP, as well as connect to a router in the usual way. (but not at the same time, one or the other)
Doesn't the hotspot procedure given by el presidente work regardless of what wifi device you have?
You must know somebody with a wifi enabled pc, the only way to know for sure is try it out.
Yeah I have to try out
