Hi, i'm new, and want to ask, i know that i need to have apps2sd, i installed it in phone and what next? How to move apps to sd?
Thank you
+ Factory junk
(2 of my games are 15MB
each and another app is 10MB
) , all backed up
1- make a list of Apps you have so you can download them again
2- or use Astro file manager to backup apps...
Then uninstall everything you can in the normal way.
then re-install all the apps, either one by one if Option1 above or using Astro file managers Restore from Backup...
They should all then be on the SD card...
Well then i installed piano app, it made my phone storage like 4mb less, i guess apps2sd working not properly...
Thank you
