Help How To Organize Applications
Crash27
Does Anyone have an idea how to organize the applications on the flip up page. My LG Eve had it in groups and you could create your own, I would like to do something similar to my X10 if possible. I hate having all my apps jumbled together. If anyone knows a good app or any suggestions, start posting
Nothing I know of affects the App Tray except maybe the different 'launcher' apps.
However, I just use the Apps Organizer from the market and put the 'All Labels' widget or shortcut link on my desktop. The programmer just added the widget feature to the 1.5 version which to me seems a bit faster than using the shortcut to 'All Labels'.
But, check out this thread for app alternatives.
I take it you are using the stock android homescreen, if you use Timescape as your homescreen the tray changes too & it's possible to rearrange all the apps in the tray.
I just found a great app to do what I originally asked for, It is called Panda Home. It has tons of features including up to 6 slide out docks for the Home screen, and when you open your apps at the bottom it shows you a menu from AtoZ and 0-9 and you can select them by letter or number or All... The best feature is the docks, you can make them a small pop out dock or tall and wide, I have over 40 apps on my 6 docks and its amazing
