LaDrOIdBoy
Member
Now I think about it, the title of this thread might be a bit misleading. Basically, I have a rooted milestone/droid (depending where you live, i live in england) and i can overclock it with apps such as milestone overclock, set cpu etc and generally im quite happy with that.
However i found that when im downloading a rom (in zip file format) there is also a matching overclock pack in zip file format to go with the rom. I would be very grateful if someone could tell me how to use the overclock pack?
thanks
thanks
