Root How To Perform A System Dump NO PC Required
PsyMega
Android Expert
Download and install root file manager .apk from here:
http://www.mediafire.com/?pb3t8nadpe69g9j open the app grant su permissions.
Next press your menu button then press multi select and highlight all directories and then select zip just name the .zip your creating sequent_system_dump or something along those lines and then upload and your finished.
Thanks for your time
Thanks for the tutorial. I was getting so tired and delirious trying to do things with it I didnt think to make a tut. I hope you get custom recovery soon. Good luck. I have done all I can with my knowledge. As a matter of fact, maybe someone can chime in. I was able to do a whole rom dump after I made a system dump. It produced a checksum.md5, config.gz, system.info.gz, and system.tar. Where are boot.img and recovery.img?
I will look into it. I am going away for the day so might not be posting any more today. I will check out system a little more when I get a chance and post redults. Good luck hopeful this starts something in development
