[How To Port Lewa] THANKS GANNON!
jonny5449
OK plane and simple follow at your own risk
1.Get the latest version of cm7 on your phone
2 download a mdpi lewa rom
3. Delete the following folders from the cm7.zip (don't extract!!) Use 7zip or winrar. Delete apps, media, framework.
4. Copy apps,media,and framework from lewa zip and place in cm7.zip
5. Change build.prop of cm7 rom and put your rom name in their and your phones model.
6. Test it
7. If works release and give proper credits.
8. Sit back and wait for thanks lol
Thank you gannon and curious noob we all worship you :p:p
It also helps to copy the app stabililty tweak in the last part of the M7 ROM's build prop to the same place in the Host ROM of choice's build prop.
It improved the system apps stability and increased all apps opening time. I put the m4 patch in the /system/as well.
The best thing to do is try each CM-7 ROM with every different kernel that's available for Gingerbread ROM's. Some might cause the LeWa system apps to FC and some won't.
It took me the better part of a week to find the right combo to give me the best performance and stability.
