Root How to print on a custom ROM.
nsciucco
Android Expert
For those of you who print with your phones, the stock printing apk files are missing in most custom ROMS. EASY FIX.. Just take the stock printing apps and put them on your SD card then open and install. Then you will notice the print option when you hit the menu button. The apps are titled JETCET PRINT and JETCET PRINT Resources.
