sayginjedi
Hi,
I have corrupted files on the internal sdcard and wish to delete them. I tried to format the whole sd but could not succeed. Here is what I've tried:
- Format using the Settings->SD Card->Unmount, then Format: This doesn't give any error but files are still there
- Mount the phone SD to the PC, use gparted on PC delete partition: Partition is deleted but still nothing happens
- Tried to use parted on adb shell, but it is not installed (I have Drakaz 2.2)
- No relevant item in Drakaz recovery menu
What else can you suggest? And one more thing, what must I care before formatting the card? Can I boot the phone when the card is empty? Then I can put Drakaz recovery image etc. after the phone is booted.
