Root How to pull an APK from a Rom?
NaterTots
Hi Guys, I had a question. I want to pull an app from Rom and put it into mine thats on the phone.
Can I just extract it with 7zip and then put it into place on my phone then set permissions?
Thanks for the help.
Ovrrdrive, Thanks!
I was trying to move a Google Wallet app to the Rom I'm currently running.
I pulled it from one and using ESfile explorer I copied it into System/app and changed the permissions to RW-R-R. Rebooted and it worked. That was my first time doing that.
Last week I found an app I wanted to move to my rom but it wouldn't work. Not sure why.
Thanks for the help!:D
Depending on the app, sometimes there are more than one .apk that needs copied to make it work. Especially true for Sense stuffs. Downloadable apps from the market "should" work by extracting the .apk from the current rom with 7zip (or equivalent archive app) and inserting the app into the new rom before flashing. I'll give this a try next time I flash a rom. :)
