Help How To Question No 3456753?
If I drag it to the bottom a 'remove' bar comes up! I managed to get them back, more by luck than judgement
Right. If you want them at the bottom of your screen it's a fine line between the bottom row and the delete bar. Just make sure that it's not highlighted in red when you let go.
Is there software for a pc that accesses the phone? I used to have one with Nokia that also accessed the SD card, I want to copy a file to the pc but KIES wont let me.
Sorted it. I uninstalled KIES totally, then cleaned the Registry, then reinstalled with a virgin download from home site; it works beautifully AND I can now access the SC Card via windows explorer, which I could not before. It is still asking me if I want to upgrade but I would have thought I had just download the latest version.
If it's working, I'd not apply the upgrade. I did and it stopped working. Had to reinstall the old version to get it to work again.
