How to record a call with Desire HD
When you try to add the widget to your homescreen, does it not even appear in the list of available HTC Widgets? Or are you adding it and it's just not appearing?
I've heard of the HTC Widgets being temperamental.
iv installed it but the widget does not appear any where, it tells me in the notifications that its been downloaded but its not in downloads
Is it just that one there's an issue with? Try downloading another of the widgets then on a home screen, hit Menu -> Personalise -> Add Widget -> HTC Widget and see if the new one is in the list available?
The above may not be the exact method, but it's there or there abouts.
i did as you said Menu -> Personalise -> Add Widget - and installed you tube widget no problem, that works fine.
i installed tips calculator from HTC HUB same problem no widget in downloads, so seems iv got a problem with HTC HUB , cant download widgets from there?
I've heard of the issue before and I think it was resolved by unlinking the HTC Sense account then adding it again.
Given the flakiness of HTCsense.com, it might not sync again though.
hi EL PRESIDENTE....still no luck im afraid i deleted my htc account and opened another, tried to download a couple of widgets from htc hub still no luck, i can install widgets from elswhere but not there??
jujst like to say thankyou for your help in trying to rectify this problem, perhaps it wii resolve itself in time.
regards tony:)
hi
can you tell me where the recorded file is kept please
thanks
joe:)
Changes from app to app. You should find it under menu-settings within most call recording apps. If not let me know the app your using and I'll find out for you if it is still an issue.
