How to remove inbuilt applications in Lg-P692 android ?
I have a phone Lg-P692.It has android operating system version 2.3.4 (jun 04 2012).The phone was sold from
Tim-Mobile in Italy and it has some inbuilt applications like Finance,Tim applications,cubomusica,Virgilio etc
which I don't need.I have downloaded from Google Store uninstall applications but they do not recognize these applications.Can anyone tell me how to remove this inbuilt applications from my phone.
For that, you'll need root access on the phone. Unfortunately, I know of no reputable source of root instructions for your device. There is no sub-forum for that phone on this site, and googling "xda root lg p692" did not turn up any hits on xda-developers.com. It did turn up several Italian language sites, but I can't vouch for them.
You could try towelroot. It may not work, but if it doesn't, no harm done.
Just remember if you root and don't have a custom recovery, if you uninstall the wrong thing and mess your phone up, it's gonna be a lot harder to fix :thumbsupdroid:
On that note, this thread is well worth the read: BEFORE YOU ROOT READ THIS!
Being able to remove carrier/manufacturer bloatware is a great benefit of rooting - but remove the wrong thing and you can easily render your device useless. Always make a backup before you start mucking about with system apps. :thumbsupdroid:
