Hi.I assume for Titanium Backup you need the pro version to remove apps?
Hi.
No, you just tap on the app and uninstall, long pressing gives you other options which is what you're doing I assume.
Hi.When I long-press in Titanium, I get the option to uninstall Moxier, which I select. So far so good. I get a screen saying my phone will reboot twice and the application will be removed permanently. I start the process...
You're welcome.Thank you so much! Worked like a charm. I'm not sure why I thought I needed to long-press and use the "Force Remove App by recovery exploit" option, but that's what I was doing wrong.
I think long pressing catches a lot of people out.Thank you so much! Worked like a charm. I'm not sure why I thought I needed to long-press and use the "Force Remove App by recovery exploit" option, but that's what I was doing wrong.
