[How-To] Remove system apps in ICS
saxydroid
i have managed to remove these system apps and reboot without a security error appearing.
Kindle books
vzw apps
backup assistant+
lge hotspot
gmail
google+
lets golf
messaging widget
photo album
photo frame
plants vs zombies
polaris office
richnote
richnote widget
share genie
smart share
social+
vcast tones
vz navigator
here is how i managed to do this.
1.rooted
2.i used Rom Toolbox Pro ( the lite version of rom toolbox should work as well.)
3. i had my phone in usb internet Ethernet mode with usb debugging enabled while removing the app
4.from there i removed the list of apps via uninstall- automated(root) mode
5. after it finished removing the apps, i rebooted the device (do not close the app just hold the power button and press power off and reboot
6. that's all. everytime you reboot you will get some cloudservice force close. (do not remove cloudservice app.)
other apps like netflix, play movies, play music and my verizon should be removable, but I use all of them so I didn't remove them.
