There is no arrange widget option after pressing key-menu.
Where can I get google search with voice icon widget?
Thxs
Can we just confirm that you have an Xperia X8 and are running it with the stock launcher not a third party one like ADW?
The google search widget is available on your phone, on mine it is in the widget list called 'Search' but your location will dictate whether it has the microphone symbol as this is not available on all phones.
juz long press n drag it to grid icon at the center bottom to remove it.. stay there for a while to uninstall it..
Doesnt work for the stupid PirateWidget though...juz long press n drag it to grid icon at the center bottom to remove it.. stay there for a while to uninstall it..
Thanks! I just got an ADW update this morning (the latest,with the recycle bin on the top part of the main desktop) and it unistalled just fine!That's curious. I've seen some widgets or apps that don't uninstall via an uninstaller. Maybe for the pirate widget you have to go to settings>application>manage, find it there and click "uninstall". I've found a workaround for this and not only. After a session of market and loads of app downloading, I use the Shake Uninstaller. I open it, I run the apps I've installed, and if I don't like them, I just shake my phone (literaly) and the app uninstalls. The drawback for widgets is that it has to have a settings menu or any kind of menu, in which you can shake your device.
