Root How To Repair Lg Stylo Imei
Doesnt show my imei # and doesnt connect to my network only wifi so i had to switch phones for now till i fix this one it did this out of no where but my imei # says unknown
Yes my phone is rooted but never backed up my efs and ima try yhe link james provided and dee if it works if not ill come back here.
Hi i was using mine phone when it just restarted and now i get no signal no imei number everything says "unknown" is there any fix to this ? I have the lg g stylo with metro pcs and i do have a computer just incase i need it to fix this problem
Thanks in advance :)
The first posted solution is one of the best options you could have tried. If QPST, EFS Pro, etc doesn't work for you, it's not a good situation.
In no way whatsoever am I meaning to rub salt in the wound here but for anyone else reading...regardless of manufacturer, this is why an EFS backup is critical. It especially seems to be an issue with LG's as a lost IMEI is quite commonplace. This has been seen across all the major LG releases for the last several years - particularly on phones that have been rooted and flashed by unofficial means. Sorry man, but I think your solution is that there is no solution. I'm being frank, I'm being honest, I'm trying to save you the exercise in futility.
To date, I've not yet seen a Stylo revived by these methods unfortunately.
Thanks for being straight up with me thanks for the help anyways
